Problem about 1769-L31
alpine
Dec 2011
Bangkok
51
Dear All members
I have problem about CPU CompactLogix 1769-L31 as follows;
Step 1. I connect this CPU 1769-L31 with 1769-PA2 and 1769-ECR.
Step 2. Later, I power ON to 1769-PA2
But The green LED near the lamp symbol (LED Power)
on 1769-PA2 will turn OFF immediately !
1769-PA2 Not working !!
Step 3. Later, I change the another CPU to connect with this 1769-PA2
The 1769-PA2 still working properly.
I suppose that there is the problem in 1769-L31, but I don't know
what is a problem ? and solution ?
anyone please tell me how to fix this problem.
Thank all
To jstolaruk
I connect this CPU with 1769-PA2 properly.
This CPU had worked properly until the last month (May 2018), It has failed !!
When I power ON to 1769-PA2, There are no LED lamp show on both CPU
and 1769-PA2. ( I guess 1769-PA2 shutdown itself.)
But I use another CPU connect with the same 1769-PA2, They work properly.
I never encounter this problem.
Sounds like whatever has failed in the cpu crowbars the power supply. There is no procedure or instructions available to repair a cpu that I am aware of.
I'm trying to get an upload from a machine for backup purposes. The upload seems to work fine but at the end I get errors and no upload. It...
1,399
Hi All~ I have a case (designed by my boss But he has left the company) Please refer to the attached picture...
2,394
Hi Gents: I met a problem with one of my 1769-OB32 module. Some of the channels suddenly malfunction -- The light indications for the channel are...
1,602
This is my first post so I am new to this website. Well to start with I have set card dipswitch to external power supply. I am feeding 24vdc to...
28
6,978
I have a MICROLOGIX 1500 system which includes a HSC module. One of the counters is configured as a ring counter. When the counter overflow bit is...
2,892
