1771-IFE data not matching
micky
Aug 2003
DeRidder, La
83
I have a 1771-IFE/C analog card where the data that is showing in the I/O config is not matching what is the actual register that the data is going too. Any thing I'm missing here? Attached are screenshots of what I am talking about and the BTW and BTR for the card.
2018-07-23 22_32_48-191.168.0.50 - Remote Desktop Connection.png 2018-07-23 22_37_11-191.168.0.50 - Remote Desktop Connection.png
I suspect the values are changing faster then your computer screen can pick them up.
Watch them and see if they are bouncing around.
The logic screen shot and the block transfer screen shot are not going to update together.
I would also change the data format to "Two's Complement Binary" ( not causing your issue). And also use 0-4095 for the
min/max scale. Do some math in your logic for scaling to engineering units.
Hi: I recently tried connecting 2 new single-ended 4-20mA analog inputs to an existing 1771-IFE. The IFE is in a RIO chassis. The values coming...
1,410
I'm having issues saving the individual channel settings on a 1771-IFE Analog card. We recently swapped from 0-10v to 4-20ma transducers. I...
1,017
We will repair by ourselves at first by replacing few power ICs such as 78M15,79M15, 79M05 and T3055E. What is TE055E Motorola TO-252, Transistor...
1,698
Hello. Wanted to ask you seasoned vets out there about a scaling issue I'm having. Controller migration. A 1771 IFE 0-5VDC analog signal...
2,533
Hey guys, I need to replace a Allen bradley 1771-IFE-C Rev D01 analog input card as it died. It’s been a while working on AB PLC 5, do the...
1,922
