1771 ife input caculation
helloooo
Nov 2006
Mississauga
Hello, allThere is a caculation in a Rslogix 5 program. N9:0*0.0732 dest. at N9:3, The N9:0 value is from a 1771 ife input channel( pressure transducer). Module configuration range is 0-4095. And N9:3 is getting value which unit is MPa (**.*). I don't understand why using 0.0732 here. Which master can give me some idea? Thank you so much!
We will repair by ourselves at first by replacing few power ICs such as 78M15,79M15, 79M05 and T3055E. What is TE055E Motorola TO-252, Transistor...
1,700
Hi, A couple of years ago our old PLC5 system was changed to Controllogix by adding a 1756 processor, the old PLC5 racks + cards are now used as...
2,980
Got called out to check out a problem with an amp read out on the winview HMI for a 150 hp motor. Using AB PLC5 1771 IFE analog input card. When i...
2,915
I'm trying to open the BTR/W Setup Screen for pre-existing BTR/W's in Logix5 and getting the warning "no module exist in I/O configuration". I...
6,158
The plant I work in has recently begun a project of getting a long unused PLC 5/60 system back in working condition. After downloading the...
2,916
