1771 - IFM Fast Millivolt BTW error
Great leadMicky
I have now tried.
Fresh .RSP with only new files.
Test AS per Micky's link
1771-IFF A
Fast Analog Input, 16 single-ended or 8 differential channels
1771-IFF B
Fast Millivolt Input, 8 differential channels
Input voltage range specification changed from 0 to 35mV to 0 to 50mV
Changed write length from 20 21 to
8,9 ,10, - 12
then lost track will test again after I get some time
Result
Got really excited
stayed for ever in the enabled state and looked at the control word to see if DN ever happened.
added a counter to done bit to see if it was just my remote connection that's when I realized that it was close but no good result
Test
[As the manual states off the top of my head]
send a block write with a length of 0
Result
Error
Next to try
Wipe the processor / use different processor
add a HMI so i can watch what happens in more real time over a camera system.
add traps and counters to log all of my testing results
Thanks again Micky
Matt
Sorry for the confusion Mickey. I thought I had posted this earlier. It is a 1771 ifm fast millivolt series B. I must have fat fingered it during the evil copy and paste.
Preface: Kinda long, so I made section titles Intro: I just want to see if anyone here has seen anything similar. A PLC5-40 series C enhanced...
377
Existing environment shown in attached photo (Existing.jpeg) Proposed Environment shown in attached photo (New.jpeg) I am migrating a PLC5 system...
596
I have a 1756-L81e v32 using a DHRIO v7.001 in RIO scanner Driving (7) 1771 ASB Modules @ 115k baud. The Racks RPI are set at 48msecs. This system...
906
Hello, I am setting up for practice and I am having trouble seeing the 1771 Scanner in RsLinx as well as Rsnetworx My setup: slot 0 : PLC-5/40E...
982
Does anyone know the part number for that plug that plugs into the 1771 devicenet scanner? The manual just says it is a linear plug, its 5 pins.
1,056
