1771-OA to 1746-OW16 wiring conversion
TheCaptain2000
May 2004
Georgia
52
I am removing a PLC 2/02 and installing a 1747 5/03 CPU setup. In the process, I am going from (2) 1771-OA AC output modules to (1) 1746-OW16 module. The 1771-OA has L1 and L2 designations wheras the 1746 appears to only have (2) L1 designations (one for a set of 8 outputs of course). Is the neutral wire that was running from L2 on my old card not needed on the new card? If I am reading the wiring diagram to my 1746-OW16 correctly, it would appear that L2 is taken care of on the backplane.
Please confirm.
Preface: Kinda long, so I made section titles Intro: I just want to see if anyone here has seen anything similar. A PLC5-40 series C enhanced...
382
Existing environment shown in attached photo (Existing.jpeg) Proposed Environment shown in attached photo (New.jpeg) I am migrating a PLC5 system...
604
I have a 1756-L81e v32 using a DHRIO v7.001 in RIO scanner Driving (7) 1771 ASB Modules @ 115k baud. The Racks RPI are set at 48msecs. This system...
913
Hello, I am setting up for practice and I am having trouble seeing the 1771 Scanner in RsLinx as well as Rsnetworx My setup: slot 0 : PLC-5/40E...
987
Does anyone know the part number for that plug that plugs into the 1771 devicenet scanner? The manual just says it is a linear plug, its 5 pins.
1,060
