1771-QB to 1756-HYD02
KevinO
Mar 2015
BC
32
Hey there. So we are converting a machine with tempasonics from PLC5 to ControlLogix. It was originally connected to a 1771-qb module and now will be connected to a 1756-hyd02 module. I am starting to look into the process of modifying the logic to work with the new module.
Has anyone gone through this process with any insight to hurdles I will encounter? Thanks in advance.
Don't expect to re-use much code from the PLC5. The HYD02 is much better supported on the Contrologix than the QB was on the PLC5. The HYD02 uses the same motion blocks as the M02AE so if you can't find HYD02 examples then M02AE or MO2AS examples will still be a great help. All 3 modules are basically the same code with tweaks for the different feed back devices.
Thanks a lot, Peter. That gives me a good start. I also got some good documentation from Temposonics about the 1771-QB interface that was quite helpful.
I just wanted to get some advice from some of you who have upgraded from PLC5 to Contrologix and went to a 1756-HYD02 module from a 1771-QB...
3,554
Hi,I'm trying to migrate only CPU from PLC-5 to CLX and I/O modules are still PLC-5 series. I think, the migration works is almost done but I...
1,724
Hello everyone, Getting ready to upgrade a PLC-5 system to ControlLogix for a client and there is an existing 1771-DS Latching input card used...
1,536
Urgent!! Hi all I am a newbie here. Currently I am migrating from plc-5 to controlLogix. When 1771-IFE change to 1756-IF16, I am getting a...
2,382
Good morning, I'm looking for opinions on the 1771 wiring solution offered by Rockwell when upgrading from PLC 5 to ControlLogix. Thanks and...
4,847
