1771-SIM RS5000 Replacement
Dec 2010
Burlington, NC
402
We use the 1771-SIM card in a lot of our PLC5s here for when we need in panel switches for various maintenance tests. We are in the process of upgrading our PLCs to Contrologix. I as of yet have not been able to find a card in the RS5000 family that does the same thing.
Do any of you know if there is one or if not why they decided not to have one?
What kind of solutions for in panel switches do you all use that does what the 1771-SIM did?
Mort, That is a completely different type module that requires a resolver to be wired to it. The 1771-SIM just had 8 toggle switches and 8 led lights on it, no external wiring needed.
Yes, and I said closest match, you asked what alternatives you used within panels, this would do just that. 4/4 on left, and 4/4 on right make 8 in and 8 out. I realize you have to wire them, put in your own toggles and you have the same thing. Why did AB decide to do or not to do? :confused: Ask them I guess.
There is an input card made by Rockwell the 1756-SIM but AFAIK it was never sold direct to the public and is discontinued by AB but you can find them like here.
http://www.ebay.com/itm/Allen-Bradl...tal-Analog-I-O-Simulator-Module-/400669655573
Most descriptions say input and output but if my memory serves correctly they only do inputs so you would need a 8 or 16 point standard output card to have output status lights.
They sell digital and analog input simulators here also http://www.plcdev.com/plc_simulators
This is another good source for analog and temperature simulators http://www.theautomationstore.com/brands/PLC-Tools.html
I have seen those Ebay cards but I don't typically use Ebay/Amazon unless that is the only source for an old part that we need to get us back going.
If it is something I have to wire up, I might as well just use a standard input card and figure out some enclosure for the toggle switches.
Preface: Kinda long, so I made section titles Intro: I just want to see if anyone here has seen anything similar. A PLC5-40 series C enhanced...
382
Existing environment shown in attached photo (Existing.jpeg) Proposed Environment shown in attached photo (New.jpeg) I am migrating a PLC5 system...
604
I have a 1756-L81e v32 using a DHRIO v7.001 in RIO scanner Driving (7) 1771 ASB Modules @ 115k baud. The Racks RPI are set at 48msecs. This system...
914
Hello, I am setting up for practice and I am having trouble seeing the 1771 Scanner in RsLinx as well as Rsnetworx My setup: slot 0 : PLC-5/40E...
987
Does anyone know the part number for that plug that plugs into the 1771 devicenet scanner? The manual just says it is a linear plug, its 5 pins.
1,060
