1794 L34 FlexLogix R16.22 module error
gusterminator
Feb 2009
Thunder Bay
85
Hi all,
I am trying to get an 1794-IRT8 module working with my 1794-L34 Flex Logix R16.22 controller. When I add the module it faults and gives a code 16#0118 Mode Configuration Rejected Format error.
I updated the EDS files for the processor, the either net IP module and the 1794-IRT8 module. It still is giving me this error. Any analog module I try and install gives me the same error. I tested the base and module on another PLC....newer L73 with remote AENT rack and it works fine. The problem has to be with how logix 5000 is loading the configuration for that module.
Any ideas how to fix this would be great.
Good morning. I'm looking at switching out an older 1794-L34 FlexLogix PLC. My plan was to take out the FlexLogix PLC and add a 1794-AENT then add...
529
I have a customer that has a 1794-L34 and they can not communicate to it using a CP3 cable, they said that the port maybe configured to DH485 I...
1,499
Does anyone know the limitation of the Flexlogic L34 Processor I have been asked how high I can flash this processor forward from my research I...
1,237
Hi All. I have a AB 1794-L34 PLC running a program with many routines. Is there any "quick-and-dirty" way that I can measure how long it takes...
6,318
having a issue and just wondering if anyone else has run into something like this. have a l34 with 2 local busses. anytime we power down the unit...
3,562
