1794-oe12 flexio problem
rribich
Feb 2010
pittsburgh pa
what magic do i need to do to get the 1794-oe12 analog output card to give me my 4-20 ma it was configured to do. i am using a rslogix5000 processor and the configuration has no errors. do i have to do some logic to set configuration/read info? my outputs are all '0'.
First, check taht the module is running without faults. Then, chose 4-20 mA in the config tab of the module properties, for each channel.
Then, you have to use a SCL instruction in FBD, using the following parameters.
In: the variable that you want to send as an output
InEuMax: 10000
InEuMin: 0
InRawMax: The max value of your eng units
InRawMin: The min value of your eng units, in most cases is 0
Out: Th Channel of your FlexIO module, for example Module:4:O.Ch0Data, this mean a flex module, slot 4 and channel 0.
The others paramteters leave as they are.
Hello! I have a problem with ControlNet... I have a ControlNet wich consists from 7 flexbuses. In one FlexBus I need change AO module 1794-OE4...
1,678
Hi Friends, I'm facing problem in 1794-oe12 flex i/os. Im not getting 4-20ma output. i hope its a self powered. only module supply...
14,409
Hi, Can anyone help me? I have limited space on a flex I/0 rack and wanted to use a 1794-OE12 but am not sure this is compatible with PLC 5 /...
1,933
I am having issues locating the status codes and figuring out why I don't have any output from my analog output card. Here's the configuration as...
4,887
Hi I installed 1794-OE12 flex IO, the module power LED starts blinking, then I turned ON the module enable bit and resetted the Wire Off reset...
26,758
