ceilingwalker
Hello all. I have an issue I have not been able to find an answer to online. I have a 1794-VHSC connected to a Contrologix PLC and a Sick incremental encoder. Everything works fine. I have a homing routine for setting a location of a device. I jog this device and have it scaled so that it is reading distance traveled. The issue I have is, for apparently no reason and at random times, the counter will read "0" as its position, requiring I run another homing sequence. I have tried a lot of different things to get it to intentionally write a "0" however, I can't do it. My preset is set and, as part of the homing sequence, it writes this value into the counter, after the home LS is made, then broke. Any ideas would be awesome. Thank you.
