1st Programming Attempt
It looks like you are using a start/stop switch and not the more normal start N/O- momentary button with a N/C stop in Manual mode. In Auto no means of Stopping?
Didn't see any motor Overload protection.
I like to see code started with Stop logic then digital, then the analogue stuff following,
But in the end, if it works and is safe for personal and equipment that is what you are after.
I think in Auto and Running if it were switched back to Manual that would stop the Pump.
Pump Overload are you referring to Pump Temps etc....?
Jon,motor driving the pump protection,
I would suggest you have to have a dedicated system easily accessible as a means of stopping the pump even in auto (or well signed how to turn the pump off by the auto/manaual sw, but this would not be preferred), there should be a local stop station in the vicinity of the pumps.
As far as I know the UKCA mark is mandatory from 2023, and that is 9 months from now. That is not a lot of time to investigate, design, validate...
22
4,742
Hi All, I cannot seem to find a way to move a Boolean from an Arrays UDT into a DINT. I have an Array of 32 elements with a UDT data type of 4...
1,750
Stupid question i know but i know i have seen this done before and yet i cant get it to work For the preset value of a TON I want to use a tag...
1,832
Hey guys, I need help calculating first Monday of the month. Has anyone ever had to perform such calculation? Rockwell has UFDB that calculates...
2,718
Hi, I have received a copy of a PLC program for a customers Carton erector that uses a beckhoff PLC and HMI. I just downloaded the trial version...
2,274
