1st time posting, Connecting Citect Scada v7.20 thru ABCLX to Control Logix 1756-L55
JM18
Jul 2012
auckland
Hi, just starting to learn citect Scada, and im trying to connect it to the control logix, i have followed all the instructions in the "help" section and still not working. I have no idea what im doing wrong and if someone could just give me a simple instruction on how to make a connection between the two
Details
1. Using the Citect Scada in a Virtual machine
2. Set My Localhost in the Network address
3. 172.16.90.101/2 put in the port forms, as instructed in the "help" section
and one last question, is there a way to check if a connection has been made, e.i in INtouch and Rslogix, you can check archestra to confirm the connection
its my first time posting so pls bear with the format, and hopefully someone could help me out..
Thank you in advance
As far as I know the UKCA mark is mandatory from 2023, and that is 9 months from now. That is not a lot of time to investigate, design, validate...
22
4,735
Hi All, I cannot seem to find a way to move a Boolean from an Arrays UDT into a DINT. I have an Array of 32 elements with a UDT data type of 4...
1,744
Stupid question i know but i know i have seen this done before and yet i cant get it to work For the preset value of a TON I want to use a tag...
1,822
Hey guys, I need help calculating first Monday of the month. Has anyone ever had to perform such calculation? Rockwell has UFDB that calculates...
2,693
Hi, I have received a copy of a PLC program for a customers Carton erector that uses a beckhoff PLC and HMI. I just downloaded the trial version...
2,269
