2 modems to Micrologix 1200
jrluckyman
Jan 2006
Plymouth, IN
I have a micrologix 1200 with 2 comm ports.
1 is connected to an easy touch OI using DF1
The other is connected to a RF modem messaging to another micro 1200 and is also connected to a dial up modem for remote access.
I have the 2 modems connected to the same port thru a Black Box nonpowered port sharing device. I have a problem when going online with the dial up modem the message instruction thru the RF modems locks up with communication error. First is there a better way to share this port. Second does anyone have any idea what I might be doing wrong.
I have been programming several years, but due to a recent job change am new to remote comms. Any references would be welcome.
John Rogers
I have not used a modem with the ML, but have used both barcode scanners, and printers.
On one job with two scanners and two printers, I used a relay on the serial lines to switch between the scanners and the printers.
Thanks to both of you.
Jiri, The muxi port is the device I have been hoping to find. Will order as soon as approval is received.
RoTa Tech, your advice is very clever. I will certainly experiment as time allows.
This was my first post and I'm already impressed with the results.
I will share my knowledge as others have questions I have experienced.
John
I am just finishing commissioning a water treatment plant with an SLC505 but now my client has added a reservoir station that is about 10km away...
2,347
About a year ago I was working for a local Industrial Electric/Automation company and we put together an IOT Remote Monitoring/Control box. After...
1,217
I recently picked up a Viator Rs-232 Hart Modem to be able to calibrate a couple devices we recently acquired. I have a couple questions if...
4,225
I have a project that is in a remote location. There will be a PLC and HMI in the panel and the customer wants to be able to monitor and even...
17
5,056
Hi all! Could you please suggest me the best producers of radio modems with wide range antennas and rs485 interface? The purpose is covering 8km...
4,046
