Johnny Rotten
If the cable length was less than 100' and you changed the cable to cat 5 you could do this with Automation Direct: Use a dl205 with dl260 cpu, place an expansion base with an anolog input card to read your analog values, run the cable to the base with the cpu, and use an analog out card, in logic make the v-memory locations of analog in the same as the analog out, might need a 24vdc power supply, and you would have it. You would need the expansion modules, and etc. There is probably a much better way for longer runs using the serial remote master/slave modules and rs-485 over a 2 wire - but I haven't done that yet.
