205 DirectLOGIC PLCs
Badluck
Nov 2015
Oak Ridge
any one know how to do PLC-to-PLC Communications over a network using two 205 DirectLOGIC PLCs. I can't even get the example given to work.
Specify which CPUs and which ports are being used.
Post a good diagrams of your communication wiring.
Zip and the code in both PLCs.
Include screen captures of any setup windows for the ports being used.
Exactly which example are you following? Please note the source of this example.
I realize that I didn't directly answer your question.
Yes I do know how to do PLC-to-PLC Communications over a network using two 205 DirectLOGIC PLCs.
network
250 CPU's slots 1 in both have the ECOM's. with my total ignorance of communications between these units. My attempt did not work. I tried to use the sample from https://www.automationdirect.com/static/manuals/hxecomm/ch4.pdf to learn something. All I hear is a relay chatter. this system used a host computer before. the 95 host died. others had their hands on it first. erased every thing and now I have nothing to work with.
It is difficult to tell very much from your system diagram. At least it should document the IP settings for the two ECOM modules.
The example ladder program you provide reads information from the remote PLC. Is that what you want to do?
It sounds like you have a lot of learning ahead of you. Good luck.
Give AutomationDirect.com's free Technical Support department a call at 1(800) 633-0405. They can get you communicating in no time.
I have a machine I did some time ago with AD 205 (DL250-1 to be exact) and a C-more EA1-T6CL... Now we have conveyors to add - 5 of them, all with...
2,323
Today I ran into something I have not seen before. I downloaded the program and of course there was no documentation. I seen a timer or TMRF with...
1,879
Hello everyone! I need to connect to a DL205-1 CPU and, as far as I know, I need to use DirectSOFT 6 software for the connection. Is anyone...
66
We have a Beckhoff CP6201 PC and an EK1100 module communicating with it via EtherCAT in one of our machines. Due to problems with the PC, I want...
75
Hi team, I am setting up my first E200 overload unit. I came across parameter 205 StartsPerHour. The default setting is 2. I presume, the motor...
496
