Overload E200 parameter 205 StartsPerHour
Dobiwallah
Feb 2012
Napier
Hi team, I am setting up my first E200 overload unit. I came across parameter 205 StartsPerHour. The default setting is 2. I presume, the motor can only start 2 times in an hour. The maximum setting is 120. One of hour motors is moving a chain which is start stopping more than 120 times in an hour. If I set it to "0" do I disable the starts per hour?
The same for 206 StartsInterval, 207 PMTotalStats and 208 operatingHours.
Thanks.
My R55 Ingersollrand is tripping on motor overload and im falling to see the trip history it is writing Acquarring texts
132
Hi, Again, a topic about Kinetix 5100 servo drives. The controller is L33ER. The servo drive are 2198-E1020-ERS with a TLP-115-200-DJMC2A. There...
550
Hi, I'm using E300 as E3 Plus in emulation mode. E300 is Rockwell Automation's overload relay. But I get hardware fault when I enable Ground...
467
Sometimes I see that a thermal overload relay (combined with a protection against short circuits) is used instead of a MPCB (motor protection...
908
Hi everyone, I have So many E300 Control module kept dead due to Module status fault. I am trying to flash them to higher version from lower...
396
