It depends on the machine.
If, for example, it has a lot of inertia, like a high-pressure centrifugal fan, then you have to use a thermal protection relay with a higher "Overload tripping class" and that is not usually found integrated into an MPCB and therefore you have to use a separate thermal protection relay.
