E300 Overload Relay Emulation Mode Hardware Fault
Asefakaratas
Jan 2019
Istanbul
28
I'm using E300 as E3 Plus in emulation mode. E300 is Rockwell Automation's overload relay. But I get hardware fault when I enable Ground Fault from trip or warning enable parameter. Actually same situation with this technote (Knowledgebase ID: QA59485). You can access this technote if you have RA account.
If I disable ground fault there is no fault. The solution in the article is not working. I've checked firmwares, eds files but still fault occurs.
I use 193-ECM-DNT, 193-EIOGP-42-24D, 193-CBCT2 and 193-ESM-I-60A-C55. I am emulating the E3 Plus (9-45 A) model. When I checked the firmware, they are all correct. Also I can not change firmware when I enabled emulation mode.
How can I fix this problem? Do you have any solution?
Thank you.
Hi everyone, I have So many E300 Control module kept dead due to Module status fault. I am trying to flash them to higher version from lower...
397
I'm working on a E300 overload relay and I'm trying to figure out where I can find information on the communications. I'm using a preconfigured...
2,009
Hi, I'm currently trying to understand this product. A customer has asked if we can incoorporate it in a system he will be offered. The system...
3,793
Hi, Anybody can advise, where can i do device logix of E300 overload relay ? I already updated the firmware to V5. When the time i use E3plus...
6,781
Hello, This is my first time using E300 overload relay. Now i got E300 overload relay modules and want to test I/O in office because i want to...
2,001
