Test E300 overload Relay I/O by using FactoryTalk ME
minaykha
Apr 2009
singapore
96
Hello,
This is my first time using E300 overload relay.
Now i got E300 overload relay modules and want to test I/O in office because i want to make sure that module is OK,before i install it in panel.
I don't have PLC module and Ethernet Communication module to do testing in office.
So, I create FactoryTalk ME HMI application on my laptop and connect E300 relay to my laptop.
I could manage to assign input status parameter on my laptop HMI and i could test the Inputs.
But,i cannot find the parameter to trigger the output of E300.
I want to create a button on my laptopHMI and when i press button , i want to trigger the output of E300.
Anybody got any idea, why i can assign input status parameter but why not output parameter?
Thank You.
Min.
I
Hi, I am using M221 reading from 3 different sensors (modbus rs485) sharing same bus (daisy chain). I am currently using READ_VAR (in total...
87
I am trying motor startup with pf525 drive by using wizard start over ethernet communication but during direction test it's showing control error...
189
See code at the bottom. Hi all. For the story, this is my first complete project using a Rockwell PLC, I've been mostly working with Unity Pro...
795
My question is regarding the number of Test outputs vs the number of inputs in a module. In the case of a 1734-IB8S card, there are 4 test...
1,199
Hi, I have to test a control logic that required to change the input temperature as the process variable from thermocouple transmitter on the...
625
