2711C-T4T Panelview Component upload
technolog
May 2015
Ohio
320
I need to get an upload from a 2711C-T4T.
I found an old thread
http://www.plctalk.net/qanda/showthread.php?p=734222#post734222
on here that said I need to use the web server built into the HMI. I set my PCs IP address to 169.254.0.199 and subnet mask to 255.255.0.0 because Geospark said (on the old thread) 169.254.0.0 - 169.254.255.255 was the default APIPA (no idea what APIPA means!) range. However, I can't figure out what the HMI IP address is to enter it into my browser address bar.
I can't figure out how to get into the HMI's configuration screens and there doesn't appear to be a 'Goto Config' button anywhere - I've even tried pressing all the blank areas in case there's a hidden button.
Can some kind soul point me in the right direction, please?
Hi everybody, I have HMI PanelView C400 (cat: 2711C-T4T) there is a program that runs directly run as startup, I don't have access to the menu...
2,046
Hello everyone, I just want to let you guys know this site has helped me in the past so I am calling on you guys once again. I have a SLC 5/03...
3,049
I am having issues with rslinx seeing my PanelView C400. I have updated firmware, configured network port and correctly set IP address of the...
5,676
Hi, I have never used this panel before but now I have to go on site to a panel of this modell and micrologix 1400. It seems that I can develope...
1,188
hi all! i want to change my panelview550 with 2711c-T3M.. can this panel communicate with my allen-bredly controller slc 5/04? thanks in advance..
1,842
