PanelView C400 2711C-T4T
JBSGreen
Apr 2013
Green Bay, wi
I am having issues with rslinx seeing my PanelView C400. I have updated firmware, configured network port and correctly set IP address of the PanelView. Currently I can ping the C400 but rslinx can't see it by showing a yellow question mark. I have searched the ab website for a EDS file for these panelviews and come up with nothing. Any ideas would be appreciated.
You don't use RSLinx to communicate with the Panelview Compact series. You're going to have to type in the IP address of your Panelview into a web browser (I recommend Firefox). There should be an option for File Transfers on the page that comes up. RSLinx is not going to see the PVc.
...ugh...that's the latest revision...:sick:...I have yet to install it (I am still at 2.59)since I like to stay at least one release back for obvious reasons...:D
One question though, why do you need to "see" the PanelView component within the RSLinx, RSWho interface?
Thanks, I can see it through web browser. Thought maybe linx should be able to see it to but guess not.
Yeah, The PVc and Micro 800s are completely different than everything else A-B makes. It's almost better to just assume you're working with a different brand entirely. One thing that frustrates me about Rockwell/A-B is the utter lack of continuity across the product lines.
Hi everybody, I have HMI PanelView C400 (cat: 2711C-T4T) there is a program that runs directly run as startup, I don't have access to the menu...
2,057
Hello everyone... I have in use a Panelview C400. It's OK and was running fine... But my CCW asked me that need upgrade a firmware. Downloaded and...
1,407
Dear All. I have arranged an upgrade software to convert my micrologix 1000 program for ML1400. Now I am having problem communicating my ML1400...
3,147
Hello everyone 1st post here. I have a Panelview C400 connected to a micrologix 1000 using a 1761-CBL-PM02. I need to connect my computer so that...
1,649
Hello. I am new with using PLC's. I have a AB PanelView c400 that has a bad firmware flash. When it starts up, it gets stuck on "Boot" after the...
2,395
