2711r-T7T HMI data logging
shailesh_vb
Jun 2013
Pune
43
Hello Everyone,
I want to log data in USB pendrive for HJMI 2711r-T7T HMI.
I want to know what is minimum and maximum size of pendrive I can connect this HMI.
Thanks,
Shailesh
This technote gives a good breakdown on Data Logging for these terminals...
56671 - PanelView Component or PanelView 800: Data Logging
Access Level: Everyone
It also mentions that there is no practical limits on the amount of data that may be contiguously logged. So you are advised to store and restart the Data Logging every couple of days.
There is, as far as I know, no minimum and maximum size USB flash drive specifications, just that it is a USB 2.0 port. However, for the MicroSD option, they do specify that you use an industrial grade card no greater than 32GB...
2711R-UM001E-EN-E said:
Memory card -
USB port and micro-SD (Secure Digital) card – Industrial grade micro-SD cards recommended. Supports SDSC and Class 6 & Class 10 SDHC micro-SD cards, FAT32/16 formats, up to 32 GB maximum size.
I would image that any good quality USB 2.0 flash drive from 2GB to 32GB should be fine for this task.
Regards,
George
Hi everyone, i am new to this site and having a good expirience in ab, mitsubishi and festo plc programming. I am currently facing an issue with...
1,675
Good morning all, programming a Panelview 800, I have a maintained push button programmed on screen 1. I copied and pasted it to screen 2. Could...
1,167
Has anyone ever used a 2711R -T7T Panelview 800 with a Compact Logix PLC over Ethernet comms? the 2711R -T7T Panelview 800 is usually programmed...
3,951
Hi I have a problem described below: I have a panelview application which is actually running on a 2711R-T4T panelview 800 which I call the "old"...
3,544
Hi Guys, I have a little problem, i need install the archive eds for PanelView 800 (Code ref. 2711R-T7T), but i downloaded of page oficial...
3,260
