2wire inductive sensor rated 90-250vac
emeka
Dec 2012
lagos state
34
Hi guys,i av a two wire inductive sensor rated 90-250vac...please how do i connect the sensor to the mistubishi plc...i am used to the three wire type of sensor of 24vdc....please i need help...
If the mistubishi plc inputs are 24VDC you can´t. Connect the sensor to a 230VAC relay and wire the relay contac into the PLC input.
How to wire the sensor:
One side of sensor to L1, the other side of sensor to relay A1 and the A2 of the relay to N.
On a Micro 810 2080-LC10-12-AWA without a load, the two wire prox won’t light up the Input. Incidentally on a 24V version Micro 810...
2,855
In a project I've choosen for the next modul: 6ES7134-4GB11-0AB0 SIMATIC DP, ELECTRONIC MODULE FOR ET 200S, 2 AI STAND. I-4DMU 15 MM WIDE...
7,293
When you have PT100 Sensors connected in 4-wire, then u transfer a measurement to the PLC, when u use 2-wire, the PT100 works like a resistor...
7,953
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
163
I just asked tech support at Phoenix Contact a question and the answer is making me think maybe I have misunderstood relay ratings for years...
2,870
