3 phase power on ups
godfrey
Apr 2002
Charlotte, NC
412
I'm looking for a recommendation for a 3 phase ups suitable for an industrial environment (water treatment). 480V, 3 phase, 60 hz and load of around 5 kva.
What I've found so far in 3 phase only starts at 40 kva and above. It's for a large valve actuator. Thanks.
I'm looking for recommendations on 3-phase power monitors with Modbus TCP protocol. I've been using a Socomec Diris A10 to monitor 3-phase...
4,326
Hi all, I got bit on a quoted job the other day. I installed an additional power meter on an existing 3 phase CT circuit that feeds a power factor...
1,994
hi, i have some question about the single phase line-to-line for the kinetix 2000. the manual only show that contractor using for the three phase...
1,256
Trying to find/understand how best to monitor the current in a three phase circuit with a PLC. Need an analog signal that can be monitored by an...
5,737
When installing from scratch, which is the right wire color to attached first? Is it the green/ground then the white/neutral and followed by...
2,958
