DickDV
Generally, it wasn't much of a problem until IGBT's came along. These output switches switch so fast that it is easy to couple the high frequency components from the motor stator to the rotor across the air gap. To make matters worse, as the efficiencies of induction motors has been pressed upward, the air gap has been reduced. Where a standard efficient motor used to have a 1/16" air gap, a premium efficient version of that motor will have only a 1/64" air gap. The trend toward higher drive carrier frequencies has made it worse too.
The tricky thing about shaft currents is that it is very hard to predict when it will occur. It doesn't seem to follow any particular frame size pattern, motor name brand, or motor lead length. And it doesn't pop up often enough to, as a blanket rule, add shaft grounding all the time as a precaution. If there is any good news in this it is that there is a peculiar pattern etched in the races of failed bearings so a good motor shop can tell you specifically what your problem is.
Using insulated bearings or insulating sleeves in the bearing cups isn't an "always" fix either. Some of the pulses in the shaft are of such high frequency that they capacitively couple right thru the insulation to ground.
Conductive grease has been proposed and usually works very good but, if you live in the same work world I do, as soon as you turn your head, someone is going to put standard grease in that bearing and you know what happens next!
No, I like the little grounding rings by ElectroStatic Tech and Parker best. Check them out if you've got this problem.
