Help with basic setup of Kinetix 300 & TL Servo Motor
atomic10
Jun 2013
Australia
Currently tinkering with a home project for a wood router lift machine using some second hand parts from a redundant timber mill. The servo is a TLY-A220P-BJ62AA, drive is a Kinetix 300 2097-V31 Pro and the controller is a Micrologix 1400.
I installed the motor and drive, connected it to the router lift ballscrew, and programmed the PLC with indexing building block from RS sample code ID 75393
Set up the IP's, limit sensors, etc and all talking fine.
Attempted to auto tune via the inbuilt app but as the lift only has around 300mm of travel, have to abort to stop overtravel.
With the auto tune, the lift works fine. Somotor has enough juice and grunt to do the job as the ballscrew moves freely and smooth. But when I try to home or jog the motor, it attempts to move but then stalls in over current.
I tried a few values in the velocity setpoint but the motor stalls each time. I then removed the motor to allow it to spin freely and prove my settings are correct, the motor doesn't spin, then suddenly spins and it trips on over velocity when jogging even when the jogging setpoint is at 5.
I have done a little with motion control, mainly stepper motors on a CNC, but had little to no experience with servos and drives - especially the AB stuff. Any suggestions gents?
Thanks for the suggestions gents.
Didn't know about the immediate home - thanks gbradley.
Alan_505 - I have had the motor disconnected from the load to try and autotune but still get the over velocity error.
The faults below are testing the motor disconnected from load and either attempting to autotune or jog
9TuC5E4ZbPyvmdIbsIBADB2VLjDO1gaxmY48qp0iaDJYJqxGCFYJAyQILxdpXzid6P5I14aDKapoc5qKtlgUFFokGXm20Dwx_DzrK3sK5tskl7ZP7YcdFaATlkoeEjF4AUhQhyoDkTYfNUgLSKWNDpKlFzYiN0RyhadDyUbl6G3teVmymu-HElCbDC9u_-m_jOUFzT-Qzn3v1XbT1tAFWfJj27ZZb_QLgh4zes60kFhe8grbrQKuq1wDUWWmTgnEhqDj1Yqu4VYF8I00dYkCkyl-JUOj4C23hQ1eYqALsOH6ZCeH9QRyQ1p5GqeMduTbj0U2ixROapUGDuRqA_vIptGSlVfmWDkYqU0lFi55VYHWx_X3SjIEj2FRTBIgOmkKXXsWuicojDW4A8cYyvu2OOBL9bAxLOCMdN7XnY1MslGSfcVozrwW1WBKDiVkFwGIKAULDbCKwE6GFA5L8GQau00iwq6jvN-_3XWZW7Jqt5525nh3u084udfcW4QZz6F-jiMvgADlH82J8uKmJ5AI0etawM687mou_rLSPhEXjNrU-SqSEH55FQDZ0wGgvUoWCH0NMksh8qPHVjhEjLQiZrSRnlFUWFYv4CkcgDjy-AUX1J0cDszO4CQCC09Sda-_k-Xx7AF1DNTC7nkbRLhb5XNYYri53M38wbaY61Tdjg7sKPJEBFuBJc-01k03VRPhBkL4wftubZ6O8LGW-Sjx3_TjSyE2qPxPKDWFQ8xJUJsCn9ZY0_-_GncXz8S_m_2eiZ0ErFLop65tuWtWu-8qUbJkqzXiTkzEhPrH=w601-h271-no
I have tried adjusting the user units to a low value, the jog to a low value and the motor does the same thing. I'm sure its a setting that I have wrong.
ANMWtRjG096OxJqFr3LNEHw3a8WlgByhFRSbB6gBg6bmeMhUJwLVJub3yn1GUER26ZvR9iYVz7Hcv3LarccfBXGswyxEwFRd2rFdEcdNVQ1nfShehCpVt8_p72hKsQnjcu-L3Ervq6iXKM1M06tiV23j8wZ2vfWJqDVXdow-sR--scKXZ9_0QFdpSARWtrJFXOFLj3FIh7ieaMTON1tHwh8oLG3mInfRMJoFr40yd_C8O_QSNZwD4mqtBYaFb32A7OiMHcKdyESRNPV8RlBsNoR3p_C45Wprq9GolOGk0lmclz8k45hAMIo-6vO2f51OQwOYDpZQEJ7kxhVOPNPDUB2uywlmMzdch4p8hRRwm59O6XanMSz4x7GGVdclgIYcpLqcqScVzq-0HZynSsUTZTeEDpiNLz_RQKrakMeQdYgTWxutHpLnQPCnCPbqOYCmG8cHbswFB5IlnSNZtz75m4PPrq7S5G76qQRv1OCD5L2Y_OHdOoKxF3puOcBBjc0xhM-TkcFX4eEIAkwi08LwwoxlNyE6BaP-as2tTNaLwU2ap9BvdtvSMBIUACSO2N4GzvAR0lpgHTK8nZajumESy1Vj0etmDpD9lSq0qhvrfobmiiKNHzXTGZDWsIPPUwkgvdxnnqafGCrug0Fr1_D1KaZUczwXRqdUewFlW_62pUZ7RfWwYOc0PPIN62KZbGQhRyeXl8notYDtDATm2zcBgBIfEELJcOej7MpWznDZOrx05Pot3rB9gSTsthG3TKNBUdH2lKaBtVa-Ir-JHAokszDnpsoeV2z7HhkV=w784-h333-no
I have not worked with actual step7 before, only MicroWIN. HOW DO YOU DO THIS!? This software is terrible. I have a CPU315-2 DP with a few cards...
6,043
Hello there, I'm practically new to the PLC world, I'm quite familiar with Siemens TIA Portal but I'm currently tasked to program Schneider PLCs...
1,865
Hey guys. Quick question from my job assessment. b. You observe that a panel light fed by a 24vdc output is barely illuminated when the...
1,672
Hi all, I have a HACH sc200 controller with 2 sensors which I hope to connect an M221 plc to via Modbus RS485 in order to display the info on a...
2,269
I would like to find a reference guide, website, book, whatever to help me navigate the concepts of bits in a PLC program. I have been...
1,462
