celichi
Hello Everyone,
I hope we are all well.
I have an L36ERM with a 1769-OF8C/a driving a 5HP Power Flex 523 speed reference 4-20 mA.
With the pump/VFD running, the 4-20 mA command signal is oscillating, causing the VFD to oscillate between 5-10% while the PLC has the 4-20 mA command steady state.
Shields are grounded at one end only.
I have 3 pumps in total, and this is the only one with the oscillating reference.
I think I am picking up noise on the 4-20 mA signal somewhere between the wiring arm and the VFD, all in the same control panel.
What we have tried...
We swapped to a new OF8C card - problem remained.
We ran a new shielded cable from the card to the VFD outside the duct - problem remained.
We swapped to a spare Analog Output on a different slot (OF4C) - problem went away.
Other Analog Output devices are not having any oscillations.
We are going to try swapping wiring arms on the card.
Does anyone have any other suggestions, or has anyone see this or similar before?
Thanks in advance.
Thanks in advance.
