AMCI Drive Controller Susceptible to Electrical Noise?
controls2021
Dec 2021
New Jersey
Hello,
I am running a AMCI SD4840 Stepper Motor drive system with Allen Bradley CompactLogix. Every now and then when a 480VAC motor kicks in on the production line, the stepper motor and AMCI controller goes haywire. Checked every possible ground, all new shielded cabling, and moved all AC wires and components away from the AMCI control system. The problem is intermittent.
Any one else that has had issues with noise on AMCI Drive Stepper Motors before?
is the AMCI and stepper cable next to or in the 480 volt conduit?
is the AMCI cable shielded?
if yes, where is the shield ground connected? only 1 location allowed, i would put is at the plc end.
the stepper end should have the shield cable wrapped around the end of the cable several times and then shrink wrapped
james
We are currently experiencing a fault on 1 of the 3 stepper motors, keying mismatch fault. The stepper motor is SMD23E2-240A-M12S. We bought the...
1,355
Has anyone used the AMCI cards for the micrologix plc series? Have some existing machines that have the micrologix 1400 plc and they also have 4...
1,594
Greetings Plcple First post here. Begging pardon in advance. Any help with the following would be much appreciated. A 3 axis program was once...
2,076
Hello, I would like to know if anybody knows how to connect or has experiencing using an AMCI 3602 to an Ultraware 3000 for step direction...
3,903
Hi all Has anyone used a Amci smd23e stepper. I would be connecting it to a Ab clx and was Hoping someone has used it and let me know if it's any...
1,961
