AMCI cards for Allen Bradley
irondesk40
Jan 2008
nc
630
Has anyone used the AMCI cards for the micrologix plc series?
Have some existing machines that have the micrologix 1400 plc and they also have 4 expansion cards. I think 6 is the max for a 1400 and now looking at adding a servo controller. I have read that you can control the Kinetix 300 with the 1400 plc using the message instruction and at this moment not sure which direction would be the best. It appears that using the Kinetix 300 and message instructions through a ethernet connection would be the most logical.
Any suggestions.
I wanted to swap them out with a compact logix but due to cost not something that can happen on these machines.
Yes, I've used their stepper controller module (open loop) for indexing a couple of times, worked fine. They've been around a while.
It all depends on what you're trying to do. If its just simple indexing, adding the AMCI module allows you to keep your existing I/O. Personally, I would shy away from the messaging to the Kinetix unless I had absolutely no alternative.
Hello, I am running a AMCI SD4840 Stepper Motor drive system with Allen Bradley CompactLogix. Every now and then when a 480VAC motor kicks in on...
594
We are currently experiencing a fault on 1 of the 3 stepper motors, keying mismatch fault. The stepper motor is SMD23E2-240A-M12S. We bought the...
1,361
Greetings Plcple First post here. Begging pardon in advance. Any help with the following would be much appreciated. A 3 axis program was once...
2,078
Hello, I would like to know if anybody knows how to connect or has experiencing using an AMCI 3602 to an Ultraware 3000 for step direction...
3,904
Hi all Has anyone used a Amci smd23e stepper. I would be connecting it to a Ab clx and was Hoping someone has used it and let me know if it's any...
1,962
