4-20Ma Input to Stop a conveying sys
elitheei
Nov 2004
Atlanta
81
I got to monitor the Amp's of a large shredder with a CT that puts out a 4-20 then as a result of a high amp condition shut down a cv feeding this shredder, I am using a MicroLogic 1200. I am an old Modicon guy .. what is the best way to sense this value in the "AB" world and shut it down on high amp and keep it down to the load drops. I looked at GRT blk ... if this is the right track .... whats the full scale of the signal coming in .... in Modicon its 4095 .. is it .. 65535 in AB or less .. ??? The help files aren't as useful you guys! Thanks in Advance,
The best way is to convert the input signal to engineering units using the SCP function. You need to know the full scale value of the amp transmitter - the amps at 20 mA output. I use the LEQ function, but the GRT will work just as well. I also use a time delay to avoid nuiscnace trips.
Tom can you email a sample of what
you are doing, maybe if you can send me a few of the rungs I can plug that in or look it over. Thanks for the help
As a matter of policy, I like to keep everything on the forum so all can benefit equally, and when I have a mistake it can be caught by sharper eyes and minds.
If the text is hard to read, you can save it and blow it up. (Phil, how about allowing pdfs to be posted as well as jpgs and so on? It would be more convenient than zipping and so on.)
I wasn't trying to be lazy or offend
I wasn't smart enough about AB to realize that was all I need .... sorry guys I will be more careful in the furture ... rest assurd you can see by my orginal question ... no lazy bones on this end. If you need Modicon help feel free to ask .... I'm just new to AB, a little different world !!This is about a 5000 rung project so 2-3 more ... don't project laziness!!
I have a customer with a machine that is physically maced out on I/O. I have 5 Thermocouple inputs that are not used. I need a signal conditioner...
2,763
Simple Question - Standard 4-20 ma Input Card (Siemens) SO if at 4 ma we get 4000counts and at 20ma We get 26800 counts when it goes overscale...
1,342
Got a new piece of equipment that has a flow switch on it. But the flow switch is 4-20ma output and we don't have any analog inputs left and the...
19
5,187
Just asking for clarification here, but from my research all I need is a 500 ohm resistor across the AI and the common? Heres my schematic. I...
2,587
Hi all Hoping somebody can help me here. I have a system equipped with 500A / 50mV shunts and need to measure system current in the realms of...
1,644
