4 to 20ma reading
cranfob
Jan 2017
gadsden
Hello everyone, I have a 4 to 20ma reading from a pressure sensor that is going to a controller out in the field. I also need to read this signal on the plc for monitoring purposes. What would be the best way to make this happen without affecting the signal going to the controller? For the PLC I would be using an allen bradley 1794-ie8. Thanks in advance for the help.
Hello, RSLogix 500, a 4-20ma analog input to PLC is scaled for 0 to 100 psi. It is displayed as 0 to 100 psi on HMI, I want to make sure that for...
3,389
I need some help. I have a 1769-IF4 analog card that is hooked up to strain gages, the gages give a 4-20ma signal to the card. We had an...
2,055
Hi, I'm a noob after some help if possible. I have been using a Click PLC with a 0-20mA analog input module, quite happily, for some time now. I...
1,818
Hi everyone, I've attached a 4-20ma level sensor to a PLC input that is configured for current. The PLC reads the range 4-12ma just fine, but...
35
9,058
Hello all. I have a problem trying to read 4-20mA into a Micrologix 1000 Analog PLC. Not sure if my issue is with wiring, or an option within the...
3,505
