GaryS
where are you getting the 4 volts max from I see nothing there that shows that
the supply for the sensor is 10-30VDC an industry standard
the data sheet says it short circuit protected 10 to 30VDC
the min operational supply voltage is 10VDC
10/380 = 0.026 amp or 26ma
it would be able to drive the load at that
24/380 = .063 amp or 63 ma
24/200 = .12 amp or 120 ma
keep in mind that these are current regulator devices they will try to maintain the current no matter what the supply voltage is as long as it stays with in the rated range 10-30VDC
when they design the input modules they know what current and voltage will be used
all the ones I have seen actually read the voltage drop across the burden resister with a differential opamp
try to hook it up with the grounded leg of the power supply and see what happens
I looked at the sensor data sheets they are showing the input module is connected on the grounded leg of the supply
the ifm module shows connecting the sensor the same way
both the outputs X and Y are shown with the load connected to the -DC supply or Grounded side
output X - burden resistor -DC supply
output Y - burden resistor -DC supply
just make sure that both the ifm input module and the sensor are connected to the same -DC source and it should be bonded to the ground conductor
