standeven
Hi everyone,
I've attached a 4-20ma level sensor to a PLC input that is configured for current. The PLC reads the range 4-12ma just fine, but anything from 12-20ma is just read as 12ma by the PLC.
I did some measuring with the meter, and the sensor is indeed putting out 4-20ma. I also checked voltage, and the sensor outputs between 1.55 volts (when the sensor is putting out 4ma) and 4.55 volts (when the sensor is putting out 12ma). The voltage remains the same at 4.55 volts from 12-20ma.
Any ideas?
Thanks!
Any ideas?
Thanks!
