440R-ENETR (GuardLink Interface)
PLC Pie Guy
Jun 2013
Halifax
1,144
Morning Folks.
Has anybody used this new 44R-ENETR Ethernet Interface Module yet??
Here is what I have.
Stratix 2000 connecting my L30ER V30.11 , my laptop Ethernet port and my 440R-ENETR Module.
I set the switches on the front of the 440R to 001, being that I should see the module now at address 192.168.1.1. and I do!.
I can ping it and RSLinx sees it, tells me the serial number, the rev and so. I can upload EDS files and do the normal things with it.
Gateway is 0.0.0.0
Sub is 255.255.255.0
Same as other devices!
But I can't see it via web browser. My PLC is at 192.168.1.5 and my browser sees it just fine.
The PLC sees the 440R with a yellow triangle. It says in the module fault description in Studio.........................
"Service Request Error:Invalid mode or state for service request . (Code #000c) "
AND
"(Code 16#0009) Module Configuration Rejected: Parameter Error. Additional fault code 16#0000"
I have tried other IP settings, all seem to do the same, allow me to ping but not really connect completely.
I don't know what other configuration it could be asking for.
In my module properties for the 440R, I have added one safety relay. 440R-S12R2, its in place and powered.
The Module Info says (As well as knowing the REV, Ser#,and product name,
Major Fault: None
Minor Fault: None
Internal State: Unconnected
Configured: Configured
Owned: No
Module Identity: Match
Any thoughts or suggestions?
I have a Point IO safety chasis with some safety IO (1734-OBV2S cards in it). This is controlled by a GuardLogix PLC. I have two robots that I...
1,927
Good afternoon, I'm having issues resetting my safety relay. Sometimes it resets, other times it does not. We end up cycling power and hoping it...
3,933
Just wanted to get a quick opinion if anyone has any experience between these two options. Typically, I would always use 20-750-ENETR for...
595
I have a Powerflex 753 and a control logix 5000. I have configured my drive into my control logix tree via Ethernet. I am not controlling my drive...
4,300
I just finished a powerflex 755 installation and now i am trying to commission a 753 drive (firmware V9.1) I went Allen Bradley's website and...
1,560
