480 v to 400 v transformer
anazyf
Sep 2021
Saudi arabia
Hi all
Where can i find this transformer ?
DvAna
Pri 480 v 3x 0.12 A
Sec 400 v 3x 0.12 A
3 phase
Type DTS 80
50/60 Hz
Had a Bubba (real name Larry) working for me that could do this for you. He did it once in the shop I was working at and put a motor in flames.
On a 480V machine he replaced a motor with a straight 240V motor & turned it on. Serious flames after a few minutes.
When I noticed the 240 only motor I asked him why & he told me he made 240. I didn't see a 3 phase transformer added so I asked him again.
He insisted he made 240 - I said show me how. He took a wire, stripped it, counted 49 strands of copper & cut off 25 strands telling me half of 480 is 240.
Larry didn't work on motors or wiring after that.
Most of the Buck/Boost Transformers I've seen are lower than the 60v he's asking for, but if you can find them it may be the cheapest.
Autotransformer is the conventional solution...
Unless, of course, you are also looking for 400v/50hz from 460v/60hz. Then it gets more complicated. If there are any motors in the subject machine, be careful!
Good Evening , We have 4 machines that were manufactured in the UK . They came over with PowerFlex 70 400 VAC Drives on them ( 20AC022 ). Our...
3,365
Hello all, I have a question and would like a few opinions if possible. 5x 480 outlets control 5 machine. I want to run them through a contactor...
180
I will be adding contact relays and current switches to a control panel that is majority 120VAC and some 480 3-phase. The coil voltage is 24 VDC...
2,616
Wizards, I have been gone from my plant for a while and upon returning I have two, 480vac-24vdc power supplies on my desk with DEAD written on...
2,271
Okay. On a semi-impulse, I scored one of these units relatively inexpensively. A development rig upgrade over my L320ERM: 5MB user memory, 120...
1,449
