Hello,
A few years back I was having a SLC 5/05 hard faulting, losing program, and requiring a download to get going again. The processor was replaced, but at some point in the process, an AB sales guy helped me install a memory module. Actually he didn't help me, he did it, I was there.
I do remember we set a few bits in the program for the MM to do it's job. Looking at the file now, I see the following bits are set:
S:5/8 MM Loaded on Boot
S:1/12 Load MM and Run
I think those were the only ones we changed, but don't recall.
We recently had a power outage, and a few days later I noticed some of my recent edits had completely disappeared, and user set points had changed. I'm thinking the memory module loaded the program as it was told by S:5/8. When I open the most recent file, with edits, and go online it goes online but the file changes to "copy of --.RSS", and the changes are not there.
I suppose I will do a download of the recent file later today, will that put the new version into the MM?
Will I have to do a download, every time I want to change the slightest thing? Now that the processor has been replaced, and doesn't fault anymore, it seems hardly worth it if that's going to be the case.
Should I possibly, do the download this afternoon, with these 2 S: bits disabled so I don't have to shut down the plant to make a change that will last through a power outage?
Any advise would be much appreciated,
Thank You,
Byron
Thank You,
Byron
