5069-L310ER convert to run on Emulator?
theColonel26
Feb 2014
West Michigan
785
Is there a way to convert a 5069-L310ER Project to run on Logix Emulate? I tried just doing a download to the Emulator but I got an error that the controller was in the wrong slot. Then I went to convert the project over to a 5868 EmuLogix but it's not giving me that as a options in the controllers property window.
Ideas?
I don’t know the answer to this but I would like to know as well so this will help it get to the front page so hopefully someone can answer.
I'm not up on all of the latest emulation stuff going on at Rockwell, so forgive me if this is misplaced...
I do know that Rockwell has done somethin silly with changing controllers in Studio5000. While you can happily change between CompactLogix and ControlLogix (5370/5570), once you convert to the newer architecture, (5380/5580 (5069/L8x)), you cannot convert back to 5370/5570 controllers.
I only throw this out because maybe there is a similar limitation with the emulator. There is some architecure limitation that they've thrown in there. Or maybe I'm just way out there...
Hi all, Im having a weird problem with my panel and i think its the plc causing it but it could be some other component. When i power up my...
2,543
So I am helping a customer design a project He needs 10 remote I/O's (nodes) and we are thinking 1734-AENT's, most are smaller size but a couple...
3,163
Hello all I have to activate the A2 port on a CompactLogix 5069-L310ER v32 in order to use it for grabbing datas. This port is currently uncheck...
1,782
I recently downloaded a program to a 5069-L310ER PLC with 374 free blocks. After working for about 1 week the Powerflex 755 VFD's started behaving...
1,594
Hi, I am using AB 5069-L306ERS2 CPU. My system should achieve SIL-2. I have safety door switches connected to AB 5069-IB8S module, and I want to...
111
