Compactlogix 5069-L310ER overcapacity
mockranouse
Feb 2019
NY
I recently downloaded a program to a 5069-L310ER PLC with 374 free blocks. After working for about 1 week the Powerflex 755 VFD's started behaving erratically (not starting, spinning at low speeds, not stopping). I thought this may have to do with some parameters being setup wrong, but when I tried to change VFD parameters and match the drive in the PLC program I got an error that stated the PLC was overcapacity. I checked the capacity tab in controller properties and saw that it was over by 342 blocks. I was able to clear up some memory in the program and the PLC began working correctly.
What would cause the program to become overcapacity, but still be in run mode and not have any obvious fault? Are there any processes, like communications, that would use up available space in the PLC after the program is placed in run mode?
I am using Studio 5000 v32.01.00 and the firmware of the PLC is 32.012.
I tried to get an answer from AB regarding this and their response was:
"if there are many online edits done in the PLC. PLC may get full of catch data that can consume the free space."
I'm assuming this is the best answer I'm going to get from them, but it still doesn't make any sense to me. How could cache data from online edits push a controller over capacity if you can't make online edits that would use more free space than is available?
I also don't understand how an overcapacity controller doesn't throw a fault of some kind. This makes it very difficult to troubleshoot unpredictable behavior without having someone present who can connect to the controller and even then they would need to check the capacity tab in the controller properties to know that it is overcapacity.
Hello all I have to activate the A2 port on a CompactLogix 5069-L310ER v32 in order to use it for grabbing datas. This port is currently uncheck...
1,783
I want to factory Reset my 5380 (5069-L310) I have here in home lab. Reason being I want to make a Internal How-To video for Setting the IP...
546
I used GSV to get the current status of older 1769 I/O modules. What is the equivalent for new 5069-I/O ? I know individual points/channels have...
1,020
We have an installation with with 6 Compactlogix 5069-L3X0ER PLCs. Within the past week, two of the 6 have crashed with the unrecoverable fault...
2,635
Hello everyone, For my new project I want to integrate a Staübli Robot with AB PLC. I don't know how to get started with it. How can I integrate...
2,162
