5201-DFNT-DH485 & WinCC (Tia Portal) Communication
fdy12
Feb 2013
Mexico
Hi, if someone can help I would be very thankful.
I'm having some trouble trying to connect a Siemens MP377 19" Touch with a Prosoft 5201-DFNT-DH485 module. This module connects to an AB SLC503. The goal is to see the module's variables (and manipulate them) within the MP377.
Right now we are making tests with the communication between just the MP377 and the DFNT module. We have tried via OPC, but through Tia Portal we can't 'see' in the net the RSLinx OPC server.
The module works, because we have successfully connected it through RSLinx OPC Server, and the MP377 works fine too. The problem is the communication between both of them.
I appreciate any help!
Thanks,
Freddy
I forgot to mention, the connection between the MP377 and the module is via Ethernet. The RSLinx OPC Server is in a remote PC (connected to the DFNT module via DH485). Everything is connected via Ethernet to a switch with good addressing (all in the same net).
Thanks.
Can you please provide the pin-out diagram for following; which is used for Debugging of Prosoft make Modbus EtherNet TCP/IP module cat...
2,544
I have been trying to connect a Prosoft 5201-MNET-DFCM to a existing KE module. It will be used to get information from a PLC 5 using DH+ via...
2,480
Hi guys , I have beckhoff servo drive ax5201 & servo motor am8012 . i am using twincat 3 . I scanned the devises and everything is connected...
3,243
I've got an antique Matsushita(Panasonic) FP1-C24 PLC that I need to connect to. I found the software, but I'm having trouble finding the...
1,733
Has anyone here attempted to connect Ignition to a SLC with a Prosoft MVI46-DFNT? I am able to do read/writes to the card from a compactlogix but...
1,469
