Ignition connection to a Prosoft MVI46-DFNT
xgrunt
Jul 2006
22
Has anyone here attempted to connect Ignition to a SLC with a Prosoft MVI46-DFNT? I am able to do read/writes to the card from a compactlogix but I have not been able to get communications working from the Ignition Gateway.
Do you have know if the connection path is set up correctly?
There are a few examples listed in the Ignition user manual
At this point I am not sure, I believe it is but I will go over it again. I have been on the phone with Prosoft and Inductive Automation several times. I did not realize that the Prosoft cards communicate via OPC-DA not OPC-UA. I assumed that because they were like a SLC it would be over the UA driver. This is still a work in progress and I am learning as I go. I will post an update when I learn anything useful.
Hi, I have questions. I have Analog Input that need to put into Ignition Designer. But I don't know how to put?
119
Hey guys. We've been learning Ignition and going through all the courses on Inductive University. I really like the software and the things you...
20
1,157
Hardware: 5069-L320ERMS2 Software: Logix Designer 35.11 / Ignition 8.1 Issue: When attempting to write to the tag "HMI_DRV200_DynamicTrim" in...
769
Hi all, happy new year! I read a topic lately and many more before that where a lot of people saying that Ignition is damn good SCADA, so I...
339
Hello, using Ignition I want to automatically change the time zone for 30 Allen Bradley plc's at the same time, is there an efficient way to do...
458
