56rf-in-ips12
jdiameron
Jun 2015
ohio
I am working on a RFID project and I am not familier with this module.
I am using the manual (http://literature.rockwellautomation.com/idc/groups/literature/documents/um/56rf-um001_-en-p.pdf) to implement example codes.
As a first step I am trying to get the system information. For some reason I am getting two negative values for the Max Block Number(-7 it has to be 249) and IC Ref(-125). The data type of the interface block is SINT. This is something that I am reading from the block and I dont understand why I get negative values...
So anybody has experience on programming 56RF-TG-30-2KB ?:)
Yes I did set the unit to run mode. But still reading -7 for number of blocks in the unit.
Not sure what is going on here.
Hi All Project background : 16 RFID Modules running under a 1756-L73 contrologix. Issue that i have got is that every once in a while, one or...
1,417
Hi guys, Just want to ask for your expert opinion. Referencing (56rf-um001_-en-p.pdf) manual for AB RFID. See attached photo. I need to get...
1,795
