56rf - rfid readers help.
Trox
Dec 2016
United Kingdom
Hi All
Project background : 16 RFID Modules running under a 1756-L73 contrologix.
Issue that i have got is that every once in a while, one or two of the readers fault. We cant see the fault on the i/o tree, but when you swipe the RFID card it does not pick it up.
Temp. solution : unplug the 56RF modules and wait 5 secs and plug it back and it all works...
I have had to do this every once a week and sometimes more than once.
anyone out there who had this issue? any solutions.
All help appreciated, thanks in advance. :)
https://literature.rockwellautomation.com/idc/groups/literature/documents/um/56rf-um001_-en-p.pdf
The error codes are stored in the image table RFID_1:I:Channel[0].ChError and RFID_1:I:Channel[1].ChError. You have mentioned above that there is no error indicated. What about doing a channel reset?
'The channel reset bit is used to command an RFID channel reset. A value of 0
indicates that the channel is not being commanded to reset, a value of 1 indicates a
request to reset the channel'
Just a thought.
Regards,
Hi guys, Just want to ask for your expert opinion. Referencing (56rf-um001_-en-p.pdf) manual for AB RFID. See attached photo. I need to get...
1,795
Hi, I am working on a RFID project and I am not familier with this module. I am using the manual...
2,254
We have a product we are now building and are planning on using RFID tags to ID trays of product as they move through the process (5 individual...
1,441
Hi. I was wondering if any of you guys have a problem with the RFID reader/write BIS M-4A7-082-401-07-S4 from Balluff. The problem we are...
656
Good afternoon! For the past several days, I have been trying to set up this Balluff BIS018A RFID head to communicate with a Do-more BRX DM1E-M-D...
5,563
