6ES7 331-1KF02-0AB0 siemens PLC
Salrizam
May 2014
Selangor
Why when i connect all the 8ch of Analog Input(4-20mA) into the
6ES7 331-1KF02-0AB0 module the 4-20mA reading is not correct. example the input is 4mA but on the PLC was read 8mA. In this case i using 4-20mA IS Isolator before going into the PLC.
I've been fighting a problem with this 8 channel analog input card mentioned in the title. I believe it's something I'm doing in the wiring but...
1,722
Hello, In the module Simatic 6ES7 331-7KF02-0AB0, there are connected four PT100 sensors. All sensors show about 2 degrees too much (observed in...
2,075
hi, i would like to know if pins 10 & 11 have any meaning on the analog card 10---comp----11, are pins 10 & 11 supposed to bridged???
7,170
Hello dears any body can tell me about6ES7 331-1KF01-0AB0 i have to connect pt 100 with std range my wiring connection or ok cpu says card...
3,549
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
183
