7 segment led
There should be a picture in your textbook. You can wire a 4-digit LED to one 16-bit input module, or two 8-bit modules.
"Cincinnati Milacron" a page from the past, used more than a few of their "Cherry" Displays and other products.
Ha! If only that was my first mistake...:oops:
I have made many errors, blunders, mis-statements, and regretable posts over the years, and for those I apologize.
I hope that I have made a few that are useful.
Thanks a lot.
plz i have a little problem & i hope that anyone can help me.
I want to display temperature on Four digit (9999) & i have 12 bits from plc.
how can i do this & what is the best way to do this.
Thanks again
You must convert the analog output (Temperature) to digital and than from digital to BCD.
I don't know if your PLC has an instruction to convert directly from Analog to BCD.
The decimal output for 16 bits, will be 0 to 65535
How is it possible to get "-"sing with BCD seven segment LED display. With combination of four bits we get digits from 0 to 9. What should we do...
2,298
Hello, How can I drive a 7 segment LED with an S7-300.Is there any hit or tip to be able to program a LED.I want LED to show 4-20 ma output...
3,043
I have a basic understanding of truth tables and the addresses. My issue is that for every letter that I have to make, I need a truth table that...
1,455
Anyone have an idea what "ROM Segment Fault" means when booting up an old 1770-TA Programming terminal? The manual gives not reference as to what...
1,295
2,997
