Our client have a centralized machine status indicator, with the use of CFL enclosed in a colored diffuser-acrylic plastic. Each CFL is connected directly to the relay output PLC (Mitsubishi FX2N-128MR-ES/UL). This machine status indicator was running good for the past 4 years, until some PLC outputs were damaged a few months ago. Initially, I thought, it was because of its blinking function as some CFL were programmed to function as blinkers. Since the existing PLC has no spare out, we recommend to install another PLC.
Unfortunately, after we connect it to the new PLC, it still damaged its output. I measured the current, it reads only 50 mA, & voltage is 220 Vac. With this, I tried using interposing relay, surprisingly it did not damage the relay.
Any idea what was the trouble?
