8 pin mini din for 1761-cbl-pm02 needed
e-unit 79
Jun 2006
Dayton, Ohio
I ordered purchased a 1761-cbl-pmo2 from ebay, only to find the 8 pin mini din connector cut off and missing. Does anyone know where I could purchase the exact type of 8 pin mini din connector. I have searched on the net for a this exact connector and have been unlucky. I have a wiring diagram from rockwell's knowledge base so wiring the connector is not an issue. If anyone can point me a website or part number, it would be greatly appreciated. Thanks
Man, that's just plain mean. You may want to get your money back (item is not as advertised) and just get the correct cable new from the local A-B distributor. Or did you check the DigiKey website. I know they can be bought, I just don't have the particular p/n or mfg. with me right now.
Thank you, jstolaruk
I only paid $5 dollars for the cable so, I'm not out a lot of money. If I can't find an 8 pin mini din connector, I may just buy a 9 pin d shell connector and make it a serial cable. But I will check out digi-key to see what I can find.
Got your money's worth, didja ?
These connectors are identical to Appletalk connectors, as long as you're making your own cables out of surplus parts.
Too bad some people are like that.
I have used this connector in the past. Mouser is a good outfit, no minimum order, quick shipping.
Be aware, this is not an easy connection to make. You will need a SMALL tip on the soldering iron! But it can be done.
Hope this will help.
Im having to re purpose some old PlantLinc 580 wireless IO extender boxes. Im having a little trouble trying to find a cable for them. The...
2,096
I am looking for 8Pin mini-Din male connectors. To attempt to make my own cables. For FX PLC's the ones I have been seeing the pins are not the...
1,906
Hiii, I want to communicate MGate MB3180 to my ML1400 channel0 configuration as my ML1400 as Modbus RTU master. But i need pin configuration for...
1,743
Hello all, I joined this forum because I saw there was discussion about the 8 Pin Mini DIN connector on Allen Bradley. I am trying to connect...
18
9,924
That is, do all PLCs that use 8 pin mini-din for connection to PG use the same 8 pin mini DIN? In case I'm using non applicable terminology, I...
25
11,251
