RS232 and RS-485 pin configuration for 1756-nc01 to ML1400 8-pin mini Din connector
PrasannaP
Jan 2018
Bangalore
Hiii,
I want to communicate MGate MB3180 to my ML1400 channel0 configuration as my ML1400 as Modbus RTU master. But i need pin configuration for RS232 to 1756-NC01 cable and RS485 2-wire cable to 1756-NC01 cable of AB.
Hello: I have to connect a RS232 Modbus RTU slave that only has Tx, Rx and GND signals to a Modbus RTU master. However, all RS232 to RS485...
237
i have an device which can support serial (RS485,RS232),CAN protocol . i want to connect it to an existing MIB 1553B bus ,what device will I need...
99
need to set up to load applications to the PV1000 RS232/DH485 thru a SLC 5/04. Laptop is usin a PCMK to the DH+ on the SLC and the SLC is...
1,778
Sorry for the question, but after a discussion and betting with an automation colleague, there was a doubt. In the micrologix manual it says...
3,228
Hi, Can someone confirm me: If there is case with RS232 protocol there can be only 1 slave per 1 master on communication link On RS485 can be...
2,854
