8400 HighLine C communication/diagnostic cable
kalabdel
Feb 2015
Ontario
1,108
Hello gents,
Is the communication cable for the Lenze 8400 a USB to RS485? And if so can I use the Schneider one?
Kal
I thought it was special Lenze one, but worth a try. The CAN one is better option if you have many drives networked.
Thanks guys. I got a quote for the Lenze one and it was steep so I thought if it's a USB to RS485 I can get away with what I have but I guess better go with the original.
Kal
Hi, can somebody here please help as I get no response from Lenze. I need the following firmware Profinet E84DFYER V02.08.01.00 Attached is a...
1,296
There is a problem with a Lenze 8400 self-contained motor/drive unit, model 8400, with Profinet comm board E84DGFCR. The Siemens S7-300 314C-2...
1,801
Hi there, I have a Lenze C300, P300 & Top Line 8400. I have a basic application which only requires the drive to follow an external encoder...
2,413
Hi folks, I have a Controllogix in communication with a zigbee coordinator using Logix AIO for modbus tcp. This zigbee coordinator have 3 slaves...
45
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
34
