Communication lenze c300 plc & p300 HMI & 8400
AmazingTrans
Nov 2005
Illinois
38
Hi there,
I have a Lenze C300, P300 & Top Line 8400.
I have a basic application which only requires the drive to follow an external encoder. Allow Jog Manual from HMI to trigger the Drive.
This is my first time working on Lenze, and I seems to have difficulty in getting support from distributor. Hope someone can assist me.
PLC & HMI TOpics
1. I've managed to get pictures on the HMI using the VisiWinNet Smart. But I do not know how to browse tag from the HMI to reference the PLC tag.
2. Is it possible for the Screen to communicate directly to the TopLine 8400 drive directly?
3. In the engineer tool (drive tool), I see there is a communication area that has Can1,2,3,4 & Mci In, Mci Out. Not sure if this is created just because I am utilizing the "Electrical Shaft Master/Slave" Application.
But, i would like to know how i can send and receive data from the P300 plc with the drive.
Drive Topics
1. On the drive end, what parameter do i configure so that the brake releases automatically whenever the drive is enabled?
2. Which parameter do i configure so that it follows an external encoder?
Ultimately, does anybody know if there is any tutorial on the PLC, HMI, and the drive? There isn't much examples & support in comparison to AB & Siemens out there.
Hope to hear from someone.
Cheers!🍻
Hello everyone, One of our machine we use Siemens Cpu315-2dp. And this cpu communicate with 4 Lenze servo drives series 9300 via profibus. Also...
181
Hi All, I am having issues communicating between an Omron CJ2M PLC and a Lenze SMV Drive (with Ethernet Module). I have set up Network...
1,151
Hi I want to establish a connection between Lenze 8200 and s7-200 cpu 226 Using RS485 or in other words Modbus Please Help
2,277
Hi; To get communication with Lenze 9300 drives, we have arranged “PC System Bus Adapter” Type EMF2177IB. We have installed software “Easy...
3,645
Hello everyone, I have Weintek HMI and three Lenze power inverters which should communicate with HMI via CANOpen. I have no problem with PDOs...
4,028
