9300-usbs adaptor
DUNK
Aug 2006
south carolina
83
Simple question...
I just received a new 9300-usbs adaptor. While installing the software I got one of those wonderfull error boxes telling me that it has not passed Logo Testing. Instead of spending hours scrolling through the Rockwell Automation website I was wondering if any of you guys knew if the 9300 USB adaptor was compatible with XP pro??
Thanks,
DUNK
Don't sweat the unsigned driver warning. The 9300-USBS is used almost exclusively on XP Pro operating systems.
Related: The new 1761-NET-ENI utility for the Series D modules resolves the USB/RS232 incompatibility, and the new utility will work with the 9300-USBS and most other USB/RS232 converters. It will configure all Series of 1761-NET-ENI modules.
Related and tired: The RSLinx Classic 1747-PIC/AIC+ driver does not work with any kind of USB/RS232 converter. Use the 1747-UIC device instead.
Which driver in Linx?
Installing the 9300-USBS and all is well with Windows recognizing the device but my question is which driver do i use when setting it up in linx? is this dependant on what device i want to connect to?
for instance if i want to connect to a panelview do i configure AB-DF1 or RS232 DF1 devices and use COM7 (which is where Windows put it)?
thanks
I have Windows 7 Pro and am trying to configure ABs 9300-USBS USB to RS232 adapter. I have done it in Windows XP but am having problems with Win 7...
2,293
Hi Just Installed an AB 9300 USB adapter on a Win7 (32bit) laptop and all is working fine to SLC and MicroLogix PLCs. Since we have some...
1,626
Has anyone used a allen bradley 9300 USBS on windows 7 pro 32 bit? I know it works well with XP pro but I'm not really seeing any support from AB...
3,032
Gents, I've a brand new 9300-USBS USB to serial converter, but the drivers supplied on the CD or on the site of Rockwell won't work. I've a Dell...
26,802
Does anyone know where I can get a free download for the 9300-usbs adapter I have seem to misplace the device driver CD that came with the...
7,245
